Hello
I been trying to figure out how to capture a mpg file from pc to a vhs tape.
Basically I have several vob files created from a minidvd camera.
I merged and edited the vob files into one large mpg file.
The file total size is 4.8 gigs
The reason I'm wanting to transfer this over to a vhs tape is because the relative I'm sending the tape to only has a vcr.
I have a happauge pvr250.
I've done vhs to dvd before no issue,but I'm wanting the reverse.
So basically I'm trying to find out to capture mpg file to vhs tape without buying any additional hardware.
2 ways:
- If your video card (not the pvr250) has TV out, hook it up to the VCR, play the mpg full screen on your computer, and record it in a VCR.
- Author the mpg as Video DVD. Hook your DVD player up to the VCR, Play the DVD in the DVD player, record it on tape on the VCR.
/Mats -
This would normally be done through the display card to composite + audio off the sound card.Originally Posted by Coxjeet
What display card do you have?
Another way is to burn a DVD and record off a DVD player.
vhs tape will NOT move through vhs recorder at all
By tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 13:31 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Good bitrate to encode a DV file captured from a VHS tape to h264 mp4?
By incubuscsg in forum Video ConversionReplies: 2Last Post: 4th Nov 2010, 17:30 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32 -
Question about capturing VHS tape to .avi file
By rfdillon in forum Capturing and VCRReplies: 6Last Post: 27th Jul 2008, 01:44
