    Jul 2007
    I recently burned an avi file on a dvd and i had problems playing it in two out of three of my dvd players. In one of them it played perfectly fine!! In the other though, when i put it in, it said that the playback feature was not on the dvd. I used a dvd+r. Another day i burned a avi file on dvd and it worked on everyone of my dvd players. So i tryed the put the first one back in to see if that one worked and it didnt again. Then i burned the file that didnt work on an dvd-r and it said the same thing. Why does it say no playback feature? I also used convertxtodvd.
    Apr 2004
    Miskatonic U
    What is the DVD player in question ?
    It sounds like a poorly worded error message, and could mean any number of things.
    Read my blog here.
    Jul 2007
    the dvd player it didnt work in was a cheap symphonic.
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    My first guess would be media. Ensure you are using a quality media.
    My second guess, would be an aging/failing laser in the Symphonic. Recordable media is harder for a player to read (requires more laser power). As players age, the lasers weaken, and the first type of media to exhibit problems is recordable media.
    Google is your Friend
  5. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Every once in a while convertxtodvd spits out a DVD that won't read in my set top player. Whenever that happens I just use IMGTools to create an ISO from the files convertxtodvd outputs and burn it with DVDDecrypter and it plays fine.
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
