It seems to me, on the surface anyway, that there should be a simple & free way to capture whatever audio is coming through my speakers. Whether I'm playing a game, visiting a website, or voice-chatting online, if sound is coming through my speakers, shouldn't there be an easy way to capture it?
I'm hoping there's a simple answer to this, and I'd also appreciate an explanation on how to do it.
Thank you!
-Chauncey
Here's the last free version of SilentBob. It's pretty self explanatory
silentbob.zip -
A lot (not all) soundcards allow 'what you hear' recording. It will usually show up in your Mixer applet as 'Stereo Mix' if yours does. All you need to record with these is a simple editor like Audacity. For those systems that don't have the 'Mix' available, and for some programs that use 'Direct Sound' you can use a virtual sound card like TotalRecorder.
SilentBob & Audacity didn't work for me, but TotalRecorder did. THANKS!!
-Chauncey
How do I: Record Video, Audio from MIC, AND Audio playing from speakers?
By miimaster2 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 21:51 -
Does 7.1 audio limit the rear speakers and divert to the side speakers?
By yoda313 in forum AudioReplies: 0Last Post: 4th Oct 2009, 10:55 -
Routing audio from PC to diffrent speakers?
By blackflag10 in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2009, 19:49 -
Venturing into Audio -- Headset vs Speakers
By solarblast in forum AudioReplies: 10Last Post: 29th Oct 2008, 21:37 -
Audio speakers - TV sound
By sldub in forum AudioReplies: 2Last Post: 9th Oct 2007, 12:08
