Many thanks!
Is there any advantage to using LeakKernelDeint over any other deinterlacer?
Results 31 to 35 of 35
This is very slightly smoother than the original video but not what I would call smooth. And there's no reason it should be much smoother. I wonder if you really have a different problem.Code:
MPEG2Source("E:\1981\VIDEO_TS\project.d2v") SmoothDeinterlace(tff=true) SmoothFPS(60)
How are you judging the smoothness of your video files? When you watch the original DVD on your TV do you see 5 little jerks every second? Or does it look like the video is vibrating 25 times a second? Is your TV a standard definition interlaced CRT? Or a progressive LCD or somesuch? -
My TV is a standard definition CRT, yeah. On the TV, it seems to jerk every 5 seconds. Definitely not with every frame.
By the way, when I loaded the actual VOB file into DGIndex and tried to save the project, I received a message that the Field order transition was incorrect and asked me if I wanted it fixed. Of course, I clicked yes.
I don't know whether that's the field transition throughout the video, or whether it's in isolated places... -
A jerk every 5 seconds? That is not the problem we've been addressing. That is some kind of timecode or multiplexing problem.Originally Posted by PTRACER
Not every 5 seconds sorry, it's been a long day.
It's been jerking as you saw in the first video I posted.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Bad deinterlacing when recording NTSC video on PAL sDVD recorder.
By ramrod1234 in forum Capturing and VCRReplies: 10Last Post: 12th Oct 2009, 10:16 -
What should I do w/ Video OpenDivX4 720x480 24.975 PAL/NTSC? fix or convert
By JoeBolden in forum Video ConversionReplies: 1Last Post: 15th Dec 2007, 23:12 -
Fixing bad PAL->NTSC conversion
By Goldmonkey2828 in forum Video ConversionReplies: 1Last Post: 30th Aug 2007, 20:40 -
Fix ghost effect in a bad ntsc to pal converted original DVD
By Talayero in forum Video ConversionReplies: 8Last Post: 16th Jul 2007, 06:40
