I have two questions:
Will Webroot Spysweeper 5.5 work ok with Vista 64?
Other than Symantec stuff is there a firewall that will work with Vista 64?
Presently I am using the Beta version of Comodo firewall. It works well, but is a little annoying while it learns my system.
Prior to this I used the one built into Vista, which is decent but didn't always leave me feeling confident, I like to know what's trying to exit my system without my permission.
I have also used Sphynx Free Firewall but I don't remember why I stopped.
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
I don't know about SpySweep, but I use the latest freeware version of Zone Alarm firewall. It works great with Vista. The Vista firewall is all but useless. It blocks 'zero' outgoing packets.
This leaves you wide open if you have spyware or malware that 'phones home'.
ZA: http://www.zonealarm.com/store/content/company/products/znalm/freeDownload.jsp Then check the box near the bottom that says 'I only want basic ZoneAlarm protection' and you can download the freeware firewall. I will likely purchase the full version also as it's still the only decent Vista firewall, IMO.
But I have Vista32. I don't know how it works with V64. You may have to look around their site to check compatibility or ask them.
best vista firewall
By Tbag in forum ComputerReplies: 51Last Post: 21st Oct 2008, 20:41 -
Is built in Vista firewall any good if not what recomended + parrallel port
By Rudyard in forum ComputerReplies: 20Last Post: 28th Jul 2008, 03:58 -
Comodo Firewall Pro - Free firewall
By bluemoss in forum ComputerReplies: 7Last Post: 10th Nov 2007, 10:44 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 13:01 -
Install McAffee Firewall and an Anti-Virus on Vista?
By Garibaldi in forum ComputerReplies: 2Last Post: 24th Jun 2007, 09:11
