  1. Sorry for caps, but need help badly.
    Bought 300 blank discs today and 10 cd-rw discs as i have 9gb of music to burn onto disc and really need to get it done (I'm on 56k and don't want to lose them).
    Anyways, i tried first off just testing burning a song onto cd-rw as if it went wrong, it wouldn't matter as cd-rw can be overwritten, anyways, i got this error.
    T0100: I/O error (04/09/00) - CD-Recorder error - track following error
    T7127: TrackWriter error - Flush failed
    T7118: TrackWriter error - Command retry failed
    I use Easy Cd Creator as nero doesn't work with my burner.
    Anyone got any help pls, im desperate, thanks!
    Ross
    BTW, i'm using Windows 98.
    May 2001
    PokeMP3
    it means you need to post some more clear tropic lines please.
    anyway, about the cd, i guess you got yourself some bad cds or some bad audio. try making it wave first
  3. good way to get yourself noticed. Write ur porblem clearly dude!
    Please mention your PC config properly. ur Prcessor, hdd, ram etc specs they help in analyesis of probs. which is your model no and make of burner ? and when did you buy it ? are u using latest software burner drivers. ?
    use the cd mastering application which originally came with ur burner. it shloud have an audio Cd burning application.
    your 9GB music is envying me. Is it MP3 or in wav format. Wish you could send me some good trance music . Try to come on Kazaa or morpheus !
    USE this pprogram Feurio - www.Feurio.com to burn audio Cds.(its good)
    OR
    use latest version of NERO - 5.5.6.4 to burn Cds. your recorder burner may be supported.
    REMBER THE RULE - first check out on CD-RWs (and erase before burning again !)
    then when u r satisfeid and everythings well by Gods grace then burn on Cd-R. NEver use IMation 650 or 700 Mb disc. They are nasty pieces and dont perform.
    Also defrag and scandisk ur hdd onece a week. check ur connectoions from the recorder to PC (only in external writers)
    and dude dont buy 300 discs at one go. sometimes the whole lot is sploit. first check with your recorder u cud burn test discs and then play them
    if need more help mail me or post reply on the site .
    hope this helps you - good luck !
