    Jul 2002
    Hi,
    My DVD player will play avi, and I am wondering how would I burn the avi's with a dvd menu without converting to avi? The burning program I use in nero. Is there different burning software that will do this or how will nero do put a menu in?
    THanks soo much!
    Apr 2004
    Miskatonic U
    If your DVD player is not Divx Ultra certified then you can.
    If it is Divx Ultra certified then you can use either Divx Author, or the latest version of Tmpgenc DVD Author to create menus, add chapters etc. However these can only be played back on a Divx Ultra certified player, or on a PC using the Divx Player. If played back on a standard Divx capable player the menus etc will be ignored.
    Read my blog here.
