I have not been able to convert my mjpeg avi into a working vcd and have heard of other people having the same problem with tmpegenc but I don't want to move to a different program so what am I doing wrong to get this error.
"video bitrate and system clock reference has errors"
one question I have but am unable to test right know isthat I use 2 pass VBR could that be the problem
You know, I have never had any problems (I too prefer MJEG to Huffy..) Tell me your exact process and I'll see what I can do.
Macros -
2 pass vbr would be for an SVCD, so I am unsure if you're making a vcd or svcd.
If it will not open the file, go to your ENVIRONMETAL SETTINGS (on main TMPG interface it is under OPTIONS) and go to your modules, UP the PRIORITY on your DirectSHow Filter in TMPG. This filter is responsible for reading mpeg, avi, etc clips. This may help you out.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
It turns out the problem was the vbr I turned it off and it works fine now
If you were trying to create a standard compliant VCD then the VBR was definately the problem. VCD use a CBR, just use the VCD template and tweak from there.
Correct Project and Sequence Settings for footage from Panasonic TM300?
By Bloodredthorn in forum EditingReplies: 0Last Post: 20th Jan 2012, 12:34 -
Correct Settings for 16:9 Anamorphic DVD?
By helplessandlost in forum Authoring (DVD)Replies: 0Last Post: 17th Jan 2010, 11:47 -
Correct Settings in Image Burn for HD-DVD?
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 17th Jan 2009, 17:01 -
Correct settings for encoding video for the 'new' YouTube format?
By Captain Satellite in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2008, 17:45 -
Belight settings for correct wave/ac3 volume conversion?
By spiritgumm in forum AudioReplies: 0Last Post: 29th Feb 2008, 12:19
