I'm trying to cut out a few seconds from a video file in vdub by using mark in and mark out, then selecting "save old format avi", but the output file suffers a slight quality loss. The source file was a divx. My main concern is keeping the quality the exact same, I don't care about file size. Is 'save old format avi' even the right way to do this?
I have other source files which I've tried this with, that aren't divx - but the result are the same.
Also, on a related note - Some VOB files that I'm trying this with, the ouput file seems to have a distorted pixel aspect ratio. It looks like the output file has 1:1 instead of 4:3 - like the picture has been stretched vertically and is taller than wide. Again, I supposed "save old format avi" isn't the correct way to do this.
Select video->direct stream copy and audio->direct stream copy and you wont lose any quality.
after I select direct stream copy, I just proceed as normal and use 'save old format avi' ?
I believe "old format avi" is the original AVI definition without ODML extensions. You won't be able to exceed -- what was it? -- 2 GB. There's really no need to use the old format unless you have some other program/player that can't handle the ODML extensions.Originally Posted by mr-scarface
Using "AnyVideo" to convert avi, mkv, etc... to HD format
By greatnitz in forum Newbie / General discussionsReplies: 3Last Post: 30th Sep 2011, 06:53 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 21:50 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 08:40 -
How to save the "Plug In Chainer" in Sound Forge 9.0
By mlong30 in forum AudioReplies: 1Last Post: 14th Jun 2009, 05:13
