I've got to spec out some new systems and I was wondering if anyone can suggest an LGA 775 that you personally know of which registers above 2GB RAM for Windows. Not all of them do. I'm going to load them up with 4GB. The Mac Pro steadfastly refuses to register above 2GB RAM, even though you physically install 4.
I have a Gigabyte LGA775 - GA-81945GMF that allows 4GB to be installed. However, the mobo user manual states:
"Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount. For example, 4GB of memory size will instead be shown as 3.xxGB memory during system startup"
I only have 512MB, sor I can't comment on actual results.
I hope this is of some use to you. -
Thanks Brosco
I'm currently checking out the DFI Blood Iron
http://www.newegg.com/Product/Product.asp?item=N82E16813136038
I've had excellent luck with DFI Mobos. Built about a dozen of them a few years back and each one booted perfectly. Just gotta check if it'll support 4GB -
You'd be hard pressed to find ANY mobo that doesn't support 8GB these days...It's the OS you've got to worry about. In order to use more than ~3.5GB on a machine you'll need a 64-bit OS.
Cool. That's what I figured. It was that damn Mac Pro running Bootcamp that threw me for a loop. Thanks.
Just got two of the Blood Irons in - They're Nice! The system started correctly on first boot (I love when that happens). I partitioned the drives into 2 for testing - XP32 vs XP64. First thing of interest:
XP64
XP32
3.25GB of RAM with the /3GB /PAE switches activated in Boot.ini
software to edit iphone videos on a 1.6ghz cpu, 2gb of ram, 30gb free space
By v1p0n3 in forum EditingReplies: 0Last Post: 17th Feb 2012, 07:47 -
transfert problem DVD HR-775 250Mo
By cyril253 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th Jun 2011, 12:10 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 13:04 -
The Future of Socket 775
By wulf109 in forum ComputerReplies: 1Last Post: 29th Jan 2010, 01:55 -
Which one is better? Shrink 4GB movie to 2GB MPG or 2GB Xvid?
By volam in forum Video ConversionReplies: 4Last Post: 13th Jun 2009, 02:20
