Has anyone found a GOOD way to make small corrections on Ink Jet printed labels. ?
Can you use "white out" or something that achieves that effect?
Thanks,
JP
I suggest making the corrections you want in your image editing program, then re-print the label.
But stick-on labels will eventually ruin the playback of your discs.
https://forum.videohelp.com/topic138166.html -
Thanks for that...I realize I didn't make my question clear.
I don't use labels because they can cause problems, especially with DVD's.
I needed to correct information that was printed directly onto the disc. If it affected only one disc, I would just reburn and reprint, but the problem is larger than that.
Thanks again.
JP -
SO you want a way to "correct" some ink jet printed DVd's?
Dont be such a cheap Skate . Correct image and re-burn. How much is your time worth? how much do blank discs cost?
Your time £10 per hour ($20 or 15e)
blank discs £10 for 50,maybe more
Alternatively .. wash the image off the discs, air dry thoroughly, then re-print.Corned beef is now made to a higher standard than at any time in history.
Sorry, I didn't expect the topic to become a personal assault.Originally Posted by RabidDog
The discs aren't mine, and the time to completely remake them would be a problem. Each label has multiple differences, so the editing time would be large. We are talking about 375 discs, created over about a year.
Now, you said WASH them....is that possible? Will the discs still be printable? Do you use detergent and water or some specific cleaner? -
Ink jet inks are water soluble or self soluble (they dissolve in the ink). Various ink refill kits include a solvent to clean printheads which also can be used.
I buy blank DVD's for 20 cents a disk or less, can reburn SL DVDs I have previously burned in 10-15 min. How long do you think it will take you to cleanup the disks you have?
A modern drive like an LG-H42, riplock removal if necessary, and 18x burning is my recommendation. Others might recommend TY disks at a higher price, and burning at half-speed - which might leave more time to try to diddle your disks, but I doubt if it wwill be enough and that the results will be satisfactory.
Question about Ink Jet printableDVD's
By flyin-lowe in forum Authoring (DVD)Replies: 7Last Post: 23rd Nov 2010, 20:40 -
How does suprip1.16 work and how does it store your corrections?
By cal_tony in forum SubtitleReplies: 1Last Post: 19th Jun 2010, 12:32 -
Unknown cool futuristic Fighter Jet...
By retroborg in forum Off topicReplies: 10Last Post: 21st Nov 2008, 14:00 -
Ink Jet printable DVD Dual Layer RW
By vegasarian in forum Authoring (DVD)Replies: 3Last Post: 7th Aug 2007, 10:31
