l have a Linksys wrk54g model which l used till recently with a linksy notebook adapter card in my toshiba laptop. Anyway the toshiba laptop had a motherboard fault so l bought a new packard bell laptop which has wireless enabled so l dont have to use the adapter card anymore. The problem is the linksys router picks up the wireless laptop but after so long it loses or says limited connectivety and a yellow tri-angle next to the wireless icon in taskbar, this even says this when it says l have a good signal.Everytime this happens and it will happen everytime l shut down and start up again l have to switch the modem and router off and back on to get a signal. This never use to happen on the toshiba laptop.What could be the problem and how to sort it out please..
Thats not a problem with your wireless connection. Its in the properties of your connection in windows.
If you go into the control panel and then network connections, right click on your wireless connection icon and go to properties. Somewhere in there you will see an option that says *something like* "notify me when I have limited or no connectivity." Uncheck it. Its just windows being silly. -
l'm on windows vista premium and l have looked into properties and there is no option to untick for limited or no connectivity....
Oh my bad. I was assuming windows XP. My apologies.
I have zero knowledge of Vista as I havent used or barely even seen it. I will have to defer to one of the uber wizards on this site.
Sorry about that ...
LG
Going wireless- what do I need?
By aelfheah in forum ComputerReplies: 11Last Post: 24th Nov 2011, 15:27 -
Wireless???
By rico1 in forum Video Streaming DownloadingReplies: 7Last Post: 4th Sep 2010, 17:40 -
Best Wireless Utility that can be used with any wireless card
By mol3000 in forum ComputerReplies: 4Last Post: 7th Jul 2009, 12:29 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 2nd Nov 2007, 23:56 -
USB Wireless lan stronger than Internal wireless?
By Super Warrior in forum ComputerReplies: 11Last Post: 6th Aug 2007, 23:26
