i have combo rioch dvd+re-writer..i have tried various software to try and rip dvds to no avail ......does anyone have any ideas...ps my machine has all relevent drivers etc![]()
What softwares have you tried ?
Did you look under the rip section to the left ?
I'd recommend using Sefy's Classical Newbie guide.
SmartRipper/DVD Decryptor / Clad / etc.
Dvd2AVI
TMPGEnc
Nero~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
where can I get SmartRipper, ReMPEG2 and DVD2AVI software. The vcdhelp site gives good instructions on how to use these but I need the software itself.
The softwares all should work. Do they even "see" the dvd drive ? Have you installed an aspi layer ? If not are your sure you tried SmartRipper (that will "create" one in Win2k /XP )?
As far as where the softwares are - Look under the TOOLS section to the left~~~Spidey~~~
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
DVD Ripping help
By nsx-r in forum DVD RippingReplies: 3Last Post: 30th Apr 2009, 19:56 -
Ripping from DVD
By SamohAD in forum DVD RippingReplies: 2Last Post: 23rd Mar 2009, 04:34 -
I need some help with DVD ripping.
By alexv305 in forum Newbie / General discussionsReplies: 3Last Post: 28th Apr 2008, 20:05 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22
