i have a ati aiw 128 pro the TV feature works great,
but with one channel i have a problem .
Channel 7 (FOX) seams to change its brightness
light/dark/light/dark and so on.
If i disconnect ati and connect a reg. TV there is no
problem.
my sys
p3 866
aiw 128 pro
mmc 7.2
latest driver from ati
thanks for any help
Hmmm.... Seems like the notorious Macrovision copy protection to me.
This is widely used in DVD and VHS, I've never heard of a TV channel using it but the symptoms are identical to the ones you're having.
To test if it's Macrovision indeed, try to record Fox airing using a VCR (it should be a new model as older ones won't detect Macrovision). Then playback the tape. If you get brightness changes, this is it.
ATI cards feature Macrovision detection but there are ways to disable it. Can't help you more with that though as I don't own an ATI card.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
