Try this:
http://geek.thinkunique.org/2007/09/04/make-an-mp3-out-of-your-video/
You'll still need to rip the video to remove any copy protection with MactheRipper or Yade X. -
Change MTR to Title Only (if you want the entire title to be a single audio file) or Title - Chapter (if you want one chapter per audio file), select the "D" button, then hit the "Streams" button. In the stream selection drawer, select only the AC3 track you want (or PCM if that's all there is). Then, extract the title or chapters you want. In the current version of MTR, you'll need to extract one chapter at a time if you want them to be separate, but in version 3.0, there will be a MUCH better interface for chapter selection. Once you have the AC3 or PCM files extracted, you'll need to convert them to a usable format. For AC3, get the freeware app mAC3Dec to convert them to MP3 or AAC. For PCM, get PCM2AIFF, or AIFF from PCM and convert them to AIFF format, which you can import into iTunes and convert to MP3.
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 11:07 -
Extract Audio from RM File without Convert it
By Bruno AUgusto in forum AudioReplies: 7Last Post: 13th Nov 2011, 09:48 -
Easy way to extract audio (DTS) from a .m2ts stream and convert it to AC3?
By marklight in forum AudioReplies: 1Last Post: 8th Sep 2008, 18:42 -
.Mkv file: Extract, convert, and add suctitle to DVD?
By Super Warrior in forum SubtitleReplies: 2Last Post: 11th Dec 2007, 19:47 -
Software to extract only PART of a DVD
By Faustus in forum DVD RippingReplies: 3Last Post: 24th Nov 2007, 05:19
