Hi, All!
I'm certain that the answer to this question is somewhere to be found in the forums, but I just can't seem to find it in my searching through them!![]()
I like to back up my DVDs as some type of mp4 - usually a Divx avi. Of course, the DVD's resolution is 720x480. Most of the DVDs are movies wih a 16:9 aspect ratio. I have been using a resolution of 704 x 400 in my mp4s. (This is the resolution suggested by Handbrake, although I usually use ffmpegx to encode.) However, I got to thinking - Am I losing 80 lines of horizontal resolution? (480-400 = 80) I tried encoding the same movie at 704x400 and at 853x480. I honestly couldn't tell a difference in the two resolutions. And the larger format played a bit jerky at times. Perhaps this was just because my computer's processor couldn't handle it.
So, what do you think? Am I losing resolution when I go to 704x400, or is it just cutting off dead space in the DVD? And, if that is the case, do any DVDs actually utilize all of their 720x480 resolution. This would make for a strange aspect ratio unless it has something to do with the non-square pixels of a TV.
Hey, on a sidenote,are LCD pixels non-square, like on a CRT?
Thanks for all your acumen, friends!!!![]()
Of course you're losing resolution by resizing from 720x480 to 704x400. Try it with a resolution test pattern and it will be obvious (unless you're cropping the frame rather than resizing).
You could encode at 720x480 and set the DAR (Display Aspect Ratio) to 16:9. That way you avoid any resizing or loss of resolution. Not all players will respect the DAR setting though. -
wOw, thanks for the insightful and fast response, jagabo!!! Does anyone know if VLC and/ or Quicktime (non-pro) will respect a DAR setting in the manner that jagabo suggests?
Also - I'm not sure what a resolution test pattern is, but I'm sure I can find something about it in the forums. -
media player classic , GOM player and probably VLC can do this
Hauppauge 1212 .MP4 - Video resolution is confusing me
By BoneKin in forum Capturing and VCRReplies: 5Last Post: 25th Oct 2012, 20:13 -
Is it possible to convert MKV to DVD and preserve 5.1 Dolby sound?
By bija in forum MacReplies: 4Last Post: 28th Jan 2010, 09:10 -
How do I join MP4 clips while retaining 1080 30P resolution ??
By nate.d in forum Newbie / General discussionsReplies: 8Last Post: 25th Dec 2009, 14:34 -
Encoding with higher resolution doesn't preserve quality.
By aznstriker92 in forum Video ConversionReplies: 50Last Post: 2nd Oct 2009, 14:38 -
Converting Avi To MP4 Ipod with custom resolution
By zander20 in forum Video ConversionReplies: 2Last Post: 28th Nov 2008, 14:59
