Hello:
My SONY RDR VX-530 has started to "reject" inserted DVD's. It gets stuck in a "LOAD" for about 5 minutes and then ejects the disc. I tried a finalized DVD (a purchased movie) and the results were the same except that in addition to it ejecting, it also displayed a "Disc cannot be played or recorded" message.
The other curious thing is that when I inserted an audio CD, it played without any problems.
Any chance that I'm just missing a firmware upgrade?
Thanks!
I agree. Most likely a failed/failing or maybe dirty laser.
Google is your Friend -
Thanks for your replies guys!
I suppose an obvious follow-up would be to get your opinion(s) as to how much $$$$$ it would cost to fix (parts/labor). I got the SONY 530 at a discount retailer last year (<$200.00) so that could affect my decision (fix/replace).
Thanks again. -
In most cases, if it isn't under warranty, it isn't cost effective to get it fixed. Most shops charge just to look at it, then parts and labor to fix it. If you can get someone to look at it cheap or free, it may be worth it. Otherwise, time for an upgrade.
Unplug it for a minute, also clean laser (after you unplug it, just take the top off to do it)....those are things you can try but don't expect too much.
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 02:03 -
I get a "could not load codec settings" with Fairuse Wizard
By felix in forum DVD RippingReplies: 3Last Post: 29th Apr 2011, 11:10 -
Cant Play / Load A RAW DV file "Codec Status Undetermined" Please
By hypnoticpimp in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2009, 14:29 -
SOLVED!! - AutoMKV stuck on "parsing profiles"... (not respondin
By TooLFooL in forum DVD RippingReplies: 7Last Post: 3rd May 2008, 08:35 -
I'm totally stuck "unrecognised message" and other errors
By marinebc11 in forum MacReplies: 22Last Post: 26th Aug 2007, 17:32
