Okay this is alot but I REALLY NEED HELP! TOLD MY CLINET THIS WOULD BE DONE A WEEK AGO. I have worked with adobe products since premiere 4.2 and am proficient and learning software quickly. If encore didnt have so many errors I would have had this done already.
I am getting pretty familiar with encore (and its many bugs) and think I have figured out how to assemble a project that will actually burn. This has taken many days and alot of reading about various errors. I am however not fully understanding the Playlist & Chapter Playlist functions. Here is my delima:
I have a pretty beefy project. It needs to have the following:
1) a play all function that plays 18 3 min clips.
2) a scene selection menu that allows the viewer to watch thier choice of the individual clips and then return to the scene selection menu. (This will actually be 2 submenus each with 9 animated buttons.)
3) a bonus features menu that goes to 2 sub menues each with 4 3 min. clips on each.
My issue is with 1 & 2.
The "play all" will be a single 58 min. file exported from premiere with chapter points.
My questions are:
1) How can I structure the layout of the project so that the scene selection menu plays the sam video files as in the timeline for play all?
2) Is there a way to "Link" Together Individual timelines for the bonus clips to behave as a "Play All"?
3) Do I need a chapter point at the end of the 58 minute "play all" Video?
And lastly I seem to have random results with encoding in encore (it transcodes some files successfully while others (coded with the same codec, pcm audio settings, bit rate etc) produce the "PGC "<my media filename>" has an error <at near the end of the timeline>" I have done alot of reading on this and it seems to be audio related but I can not distinguish any distinct differences in the clips it will transcode and those it wont other than the overall length of the clip!
That said it will not take any dolby encoded clips! has anyone had success with exporting out of premiere with dolby and can you recomend the settings that work for you.
Please answer as much as you can and thank you in advance for the help.
Reality Sets for Green Screen & Chroma Key Video Production Pros.
Reality Sets - We bring the locations to you!
www.RealitySets.com -
Dont use the product , but it would appear all that needs correcting is functionality (navigational adjustment of playback) .
That could get interesting , but have a look at some of my guides ... one has "playlist" in its title ... thats the one you should study and grab pgcedit ... thats the tool of choice .
Simple and fast for those know how ... https://forum.videohelp.com/topic322350.html
As for (3) , thats a no ... system default .
What would have been (4) , means some clips need attention , conversion prior to the product you use , will accept them , or maybe fixvts might correct the problem after the project output has been completed .
Yes ... I tell clients the same thing ... but to read the fine print when it comes to "their" clips ... guaranteed before next xmas , if not sooner .
Or send me some snaps of what project looks like loaded in pgcedit and I'll go through it .
Layout of mediainfo
By pooksahib in forum Newbie / General discussionsReplies: 4Last Post: 27th Feb 2012, 09:30 -
DVD with .layout and .LAY files
By Case in forum MacReplies: 1Last Post: 9th Sep 2010, 03:00 -
Remember your desktop icon layout for WIN XP..like win95 ezdesk? [RESOLVED]
By vhelp in forum ComputerReplies: 6Last Post: 7th Jan 2009, 10:22 -
Help in Encore
By sk8_aholic in forum Authoring (DVD)Replies: 0Last Post: 13th Nov 2008, 00:33 -
I require assistance with a layout, please.
By Zynn in forum Authoring (DVD)Replies: 3Last Post: 5th Feb 2008, 08:39
