which is the overall best writing media to use for dvd's?
Only Verbatim is to be considered for Dual Layer DVD. For single layer, there's no single best. Different hardware work best with different disks. But take a look at www.nomorecoasters.com for a comple guide.
/Mats -
I've used Verbatim and Taiyo Yuden in both DVD-R and DVD+R and had no problems. Both are high quality media as you'll find out if you go to the website Mats suggested.
If you want to burn dual layer discs, only use Verbatim DVD+R DL. Don't use any other brand and don't use DVD-R DL discs either. Most of us recommend that you burn with ImgBurn (it's freeware) for best results.
I have no idea what the answer is to your question about error handling capability. -
Errors are errors, and shouldn't occur. You want a drive that doesn't create errors. Using good media, most new writers don't. LG, NEC... the list goes on. Read the DVD Writer reviews found left. Highest user rating at the mo is NEC ND-3520A.
/Mats
Need help using Nero 7 writing
By tcory in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2011, 16:19 -
Writing while angry?
By lordsmurf in forum Off topicReplies: 5Last Post: 28th Jun 2010, 19:46 -
Writing on Black CD-R's?
By marvin00 in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2007, 11:24 -
Error writing to media
By minepup in forum DVD & Blu-ray WritersReplies: 2Last Post: 21st Jul 2007, 08:28 -
DVD Writing
By netpicker9 in forum Authoring (DVD)Replies: 5Last Post: 16th May 2007, 00:16
