which program and which way is the best?
Results 1 to 10 of 10
DVD Rebuilder is for compressing DVDs to fit a smaller size - think of it as a high quality DVD Shrink. It does not do menus.
You are relatively limited in how much you can alter an existing menu. If the work you need to do is extensive, it is often simpler to re-author.Read my blog here.
ok how do i start an with what do i start the re-authoring process?
For one menu, DVD Remake Pro is the simplest solution.
Read my blog here.
seems like it,but another question which dvd writer has the best error handling capability?
Fixing DVD so it does not skip menu on start-up
By danielmak in forum MacReplies: 6Last Post: 30th Dec 2009, 03:45 -
Fixing an out of synch dvd
By bidelman in forum RestorationReplies: 7Last Post: 10th Dec 2009, 08:47 -
Fixing title menu buttons
By Yaro in forum EditingReplies: 4Last Post: 8th Sep 2009, 04:35 -
Fixing Camcoder DVD
By EdwRom in forum Newbie / General discussionsReplies: 17Last Post: 6th Sep 2008, 08:36 -
Fixing brightness/contrast on a DVD
By Salva Veritate in forum EditingReplies: 4Last Post: 7th Oct 2007, 21:05
