ok hes my problem i have these anime videos that are converted in matroska codec and aac audio
they have dual audio files and a subttitle file
im trying to convert them to mpeg1 or vcd but i cant convert them because of the audio codec it says cant be resampled and whe ni tried with extracting and multiplexing the video and audio dont match
i used winavi to convert it to mpeg1 it worked fine but it only picked up the 1st audio file whihc is the japanese audio i would of been happy if it picked up the english audio but it didnt then i tried total video converter which lets you choose what audio file you want to keep and you can only keep one but it wont let me convert the file because it cant resample
ive tried almost every converter and extractor
i used MKVextractGUI to extract all the files within the video file
and i used virtualdubmod to multiplex but it wont pick up the codec aac then i tried using the total video converter but nothing works
i tried using a audio converter to convert the aac audio file to mp3 ac3 acm but when i multiplex the video and audio dont match
well any help would be appreciated thanks in advance
WinAVI is vile, vomitous crap.
Install the Haali Splitter, if you haven't. Then install avisynth 2.5.8 alpha.
Finally, install FAVC. Use the HCEnc encoder and the medium or high settings.
Yes, it will take a lot longer than WinAVI, but, and here is the important thing, it will work, and the quality will be twice what WinAVI could ever dream of producing.Read my blog here.
megui convert video how to keep orginal aac audio
By jamespoo in forum DVB / IPTVReplies: 0Last Post: 24th Jun 2011, 22:11 -
Convert MP4 AAC Audio possible?
By kazz0817 in forum AudioReplies: 4Last Post: 18th Apr 2011, 02:42 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 09:05 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround info
By SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 16:58
