I use InterVideo WinDVD because it came with my computer, but I used up all its sample "capture a screenshot" options.
Can someone recommend a simple & free program to capture individual screenshots, whether they be from mpg, avi, or DVD? I already tried CTRL-PRT SCR to no avail.
Thank you.![]()
-Chauncey
Also VLC
Video - Snapshot
If you are doing this from a recording, you can set deinterlace and aspect modes before the snap.
For example: 1080i sports caps are a quick snap if you first set deinterlace to field discard. The result will be 960x540. If you need the resolution try bob or mean deinterlace. -
VirtualDub Mod will also capture screen shots from those formats. You can copy it to the clipboard and process if wanted in Paint or similar then save as any format or take a 'snapshot' in .tga or .png or .bmp format. It also has the ability to move one frame at a time or jump to a keyframe.
Also my favorite, Fscapture
http://www.portablefreeware.com/download.php?id=775 -
Media Player Classic was the first recommendation, so I tried it & it meets my needs. THANKS!!
-Chauncey
How to make a video from screenshot
By LukeP in forum EditingReplies: 7Last Post: 7th Sep 2010, 15:01 -
Can't make screenshot from a video device
By jumpjack in forum Capturing and VCRReplies: 2Last Post: 2nd Apr 2010, 05:02 -
Video screenshot help
By KateP in forum Newbie / General discussionsReplies: 9Last Post: 27th Apr 2009, 02:39 -
Creating Video screenshot
By tuanvn.2007 in forum Video Streaming DownloadingReplies: 4Last Post: 21st Sep 2008, 10:37 -
Batch Screenshot Capturing from Video Input in realtime
By midimidi in forum Newbie / General discussionsReplies: 0Last Post: 14th Jul 2007, 10:10
