i did a video capture for a short film for my friend but we ran into a problem. it seems that we were only able to capture the left channel for the sound. is there anyway that we can fix this?
Make it mono or copy the left channel to the right channel. But what kind of video file is it?
It depends on the audio format, but you could separate the audio from the video (demux) and put that into a audio editor and copy the left channel to the right and output as stereo. Sometimes you can add a little bit of delay or other processing to the second channel and make it sound better than just a single channel .
Audacity is a freeware audio editor and accepts WAV and MP3 audio and a few other formats. It works like a word processor, just copy and paste.
If you need to extract the audio from the video, you may be able to use VirtualDub Mod and save it out as a WAV. Then if it's a AVI type format, you can process it and add it back in.
MPEG video is done a similar way, just different tools to demux and mux it back in.
And welcome to our forums.
Left escaping to the right ...
By megadriver in forum AudioReplies: 4Last Post: 29th Nov 2007, 12:50 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 00:45 -
TGPO has left the building
By offline in forum Off topicReplies: 58Last Post: 15th Sep 2007, 12:57 -
Confusing Right with Left...
By Thortok2000 in forum Newbie / General discussionsReplies: 17Last Post: 29th May 2007, 16:30 -
By Thortok2000 in forum Capturing and VCRReplies: 1Last Post: 29th May 2007, 09:50
