I am trying to put Lost season 2 on to Dvd, 4 episodes to one Dvd using a menu. I am in the UK and use PAL standard menus. I load everything up and make my menu look nice but when I come to start the conversion process I get a little box telling me that my first title is NTSC(film) and to change the tv standard or it may cause problems with my Dvd player. Firstly I ignored this and did the conversion anyway, but the disc, when burnt would not play, the titles were there but I could not highlight them. Next I tried again, but this time I changed the tv standard to NTSC, and the same thing happened. I wondered if I am missing something in the settings or if you know any way that this can be done. Sorry I cant post the log files as I was using version 2.5.3000 and have just installed the newer version 2.5.3100 and the log files are gone. I have tried to do it again with the new version and am getting the same warning box, but I'm not sure how to post the log file for you to look at...sorry. Any help would be greatly appreciated. Ah, I think I see where you upload the log file, fingers crossed I do it right...lol
svcd2dvdlog-20070903195335.txt
Have you got a log from a proper run as i think that one is from just previewing the menu and so doesn't give to much info.?
This is the complete log file from the conversion I did today.
svcd2dvdlog-20070904100729.txt -
Well the DVD Menu settings are PAL in that log - so that is why you have the popup.
Maybe if you change the settings on your DVD player to "Auto" for TV standard (rather that PAL or NTSC) the DVD will play ok.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
ive used the pal menu with ntsc assets many time and have come across no issues with uk players.
Pal To NTSC Menu Conversion
By Mastiland in forum Newbie / General discussionsReplies: 10Last Post: 7th Dec 2010, 14:14 -
Help. Convert menu sublayer from 720x576 to 720x480 (PAL to NTSC)
By danfisherman in forum Authoring (DVD)Replies: 6Last Post: 9th Jan 2009, 12:56 -
FPS..NTSC & PAL Standard Cinema Film/Digital
By flamingo in forum TestReplies: 0Last Post: 9th Nov 2007, 09:30 -
Quick question - PAL Menu when converting NTSC Xvid
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Oct 2007, 12:46 -
PAL to NTSC, Menu, Chapters
By heretic754 in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2007, 14:46
