Results 1 to 10 of 10
    Sep 2007
    i need a program that lets me make a dvd with 2 audio files and a subtitle file that i can turn off and on and were i can switch to japanese or english audio please post the best program
    it would be greatif tmpgenc dvd author pro had support for subtitles
    i want to make a mutli video dvd like about 10 anime episodes on one dvd but i want to have 2 audio files and 1 subtitle file please help i looked everywhere and ended up on this site so i registered
    Latest tmpgenc dvd author support subtitles.
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    GuiforDVDAuthor lets you have 3 soundtracks and 3 subtitle tracks.
    Freeware.
    Apr 2004
    Miskatonic U
    What is the total running time for your 10 anime episodes ? You may have to look at half-d1 or lower to maintain some quality if the bitrate drops. This can make subtitle placement an interesting exercise.
    Read my blog here.
    Sep 2007
    i have tmpg dvd author 3 dix but it doesnt let me add any subtitles it only lets me type in the text subttitles
    and the anime are about 22min each
    i will try some of the other programs yall posted thanks please help if you know how to add the srt file in the tmpgenc dvd author 3 thanks or any other program
    Sep 2007
    also wwhat program can i use to multiplex the video with 2 audios and get mpg format
  7. mplex, imago, bbmpeg...
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Generally you provide separate video and audio files to the authoring program. That will multiplex them (and the subtitles) in the process of authoring.
    Sep 2007
    tk187 -
    See this thread for how to import .SRTs into TDA3.[s:443aadb746][/s:443aadb746]
    Sep 2007
    okay ill try this but every time i got to menu or edit it wont work like its corrupt or something i reinstall and its still the same problem thats why i use the tda 2 the older version it works good jsut doesnt support subtitles or dixv authoring
