Just bought a dvd player that supports divx. Burned my first divx using nero to a dvd-r and poped it in. Great audio, great video, but they are not in sync. Is there a guide for this or can someone tell me what the problem is? Thanks
Were they in sync on your PC ?
Did you burn as data, or convert to DVD ?
How and with what did you burn ?
You have not filled in a location in your profile, so I don't know where you are from or what your native TV format is. However I have seen some players that lose audio sync on some files when they are converting formats on the fly (in my case, NTSC to PAL). Having the player output the native format of the file fixes this.
My preference for burning is imgburn, not only is it free and the best DVD Video burning application around, but it is only a burning application, so it will not convert files. I use it to burn data discs full of avi files and never have an issue with them.
You might also want to post what player you are using. Some players have had issues with VBR MP3 audio, which is a common format in Xvid/Divx files.Read my blog here.
OK, it's an xvid file with AC3 audio. I didn't know you could just burn a bunch as data so I guess Nero converted it on the fly and that's probably my problem. Nero did tell me that the file was mostly in PAL format, but its NTCS as well as my player/tv.
The file is in sync on my PC. So do I need to convert all my divx/xvid files to NTCS? What's the easiest way to do that? I tried the imgburn app, but it seems to only want to burn images and not individual files live avi for divx.
Thx guys
Oh, the dvd player is a Phillips DVP3960 -
DivX/XviD files get burned as data discs, no converting needed if your player is also a DivX/XviD player and make sure to finalize the disc.
I don't have the Philips model you do but my Philips 642 can have problems keeping up if the AVI contains AC3 audio.
I don't know why this works but it does for me -
after encoding my DivX w/AC3 audio, I run it through Nandub. (it has to be Nandub - not VDub)
Video - Direct stream copy
Audio - Interleaving
Enable Audio/Video Interleaving
Preload 96 ms
Interleave audio every 96 ms
Click ok
Save
burned DVD out of Sync
By agent222 in forum Video ConversionReplies: 11Last Post: 22nd Apr 2012, 23:41 -
Audio (or video?)out of sync when burned
By seragx99 in forum Authoring (DVD)Replies: 2Last Post: 28th Jul 2008, 07:05 -
Cannot read Nero-burned CDR (Vista) on XP
By walter4h in forum ComputerReplies: 4Last Post: 27th Mar 2008, 01:20 -
Burned DVD's Out of Sync
By RailheaD in forum AudioReplies: 43Last Post: 11th Dec 2007, 10:09 -
Can't copy a (ISO) DVD I just burned in Nero
By perceptionist in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 21:49
