i'm a newcomer. plz suggest me an easy-to-use software (freeware preferred) that can join my 2 parts avi video into 1, and i want then to split it into 3 equal size of parts.. so i can burn them into 3 vcd separately...
VirtualDub. Load first AVI, load second with Append segment. Make sure both audio and video are set to "Direct stream" and Save
But: To join AVI, both parts must be identical; same frame size, same bitrates, same audio & video codecs (not a limitation of VirtualDub, but how it is).
/Mats -
Yes, joining should, if at all possible, be avoided. There's always a risk for problems down that road.
How long are the AVIs? (In time)
/Mats -
Originally Posted by mats.hogberg
Yeah, and you recommend the worst tool to accomplish avi joins which fails in 90% of the cases, I think you are joking with the guy.
Use AVIMux-gui instead or mencoder, if it is 2-parts (or more) of the same clip...it is far more effective than vdub. Use only vdub to split -
i tried AviMux GUI but the output was terrible. sound not sync and the video is only include the first part of it. plz. i dont know how to start using mediacoder. its confusing even to state my choice of output format
Not mediacoder, mencoder
I would try AVIDemux first. Usually works for me.Read my blog here.
A simple program that will join groups of 4 or so video files?
By Toki_Wartooth in forum EditingReplies: 9Last Post: 3rd Jun 2010, 19:21 -
Simple question....... what is the best way to join AVI files
By True Colors in forum Newbie / General discussionsReplies: 3Last Post: 24th Apr 2010, 22:22 -
Is there a mac program that join parts of a video file in rar pieces?
By VidHunter in forum MacReplies: 5Last Post: 22nd Mar 2008, 08:58 -
Good free program to join .mpa audio and .mpg video ?
By geek2330 in forum Newbie / General discussionsReplies: 6Last Post: 5th Nov 2007, 10:34 -
Is there a good simple program to encode .avi's to mpeg?
By modartist in forum Newbie / General discussionsReplies: 7Last Post: 12th Aug 2007, 21:35
