I had to reset my system and have re installed ffmpegx.
But now when I convert to H264 its writing the audio and video as seperate files.
It didnt do this before and am even using the same file that I converted before and it worked fine.
Anyone know why its doing this and how to stop it?
Results 1 to 10 of 10
Patience. When the ffmpegX Progress shows 100% it is not finished. Two files are created, one for video and one for audio. You have to wait for thee to be merged; if you try to run one of these before the files are merged they will stay separate. Just wiat until ffmpegX Progress shows Finished. I hope this solves your problem.
return to the market place with helping hands
I've seen it take as long as five hours if the source video was goofy in some manner. At that point I abandon ffmpegX and move to MPEG Streamclip.
Hi, I just re encoded my x264 25 min file. It took about 1 hour to go from 100% to finished but there are still two seperate files. audio and video...one other file (a x264 mkv with ac3 audio) was giving me the same problem but every other file works ok so far. I'm going to try out mpegstreamclip
Here is my log of the 720p x264(a 720p xvid source with ac3)
Encoding started on Mon Sep 22 13:15:41 CDT 2008
x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2
mp4 [info]: initial delay 1001 (scale 30000)
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
configuration: --enable-memalign-hack --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
built on Apr 15 2006 04:58:19, gcc: 4.0.1 (Apple Computer, Inc. build 5250)
Input #0, avi, from '/Volumes/My Book 1TB/Vid/TV Shows/Entourage/Season 5/Entourage - SE5 E01 - Fantasy Island.720p.avi':
Duration: 00:25:14.6, start: 0.000000, bitrate: 5394 kb/s
Stream #0.0, 29.97 fps(r): Video: mpeg4, yuv420p, 1280x720
Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 384 kb/s
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0, 29.97 fps(c): Video: rawvideo, yuv420p, 1280x720, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
error, non monotone timestamps 8504496 >= 8504496
video:0kB audio:0kB global headers:0kB muxing overhead inf%
x264 [info]: slice I:679 Avg QP: 7.23 size:247667 PSNR Mean Y:56.71 U:61.39 V:61.98 Avg:57.72 Global:57.04
x264 [info]: slice P:42691 Avg QP:10.00 size:119612 PSNR Mean Y:51.38 U:53.45 V:53.79 Avg:51.99 Global:51.91
x264 [info]: slice B:1988 Avg QP:12.00 size: 42746 PSNR Mean Y:51.55 U:54.15 V:54.26 Avg:52.24 Global:52.07
x264 [info]: mb I I16..4: 10.6% 0.0% 89.4%
x264 [info]: mb P I16..4: 2.7% 0.0% 16.5% P16..4: 77.0% 0.0% 0.0% 0.0% 0.0% skip: 3.8%
x264 [info]: mb B I16..4: 0.5% 0.0% 2.8% B16..8: 67.6% 0.0% 0.0% direct:10.4% skip:18.8%
x264 [info]: final ratefactor: 23.48
x264 [info]: PSNR Mean Y:51.466 U:53.598 V:53.934 Avg:52.088 Global:51.958 kb/s:28329.97
encoded 45358 frames, 7.24 fps, 28331.37 kb/s
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/My Book 1TB/Vid/TV Shows/Entourage/Season 5/e_s5_ep1.video.mp4':
Duration: 00:25:13.4, start: 0.000000, bitrate: 28332 kb/s
Stream #0.0(und), 29.97 fps(r): Video: h264, yuv420p, 1280x720
Input #1, avi, from '/Volumes/My Book 1TB/Vid/TV Shows/Entourage/Season 5/Entourage - SE5 E01 - Fantasy Island.720p.avi':
Stream #1.0, 29.97 fps(r): Video: mpeg4, yuv420p, 1280x720
Stream #1.1: Audio: ac3, 48000 Hz, 5:1, 384 kb/s
Output #0, mp4, to '/Volumes/My Book 1TB/Vid/TV Shows/Entourage/Season 5/e_s5_ep1.audio.mp4':
Stream #0.0: Audio: aac, 48000 Hz, stereo, 192 kb/s
Stream mapping:
Stream #1.1 -> #0.0 [sync #0.0]
video:0kB audio:30558kB global headers:0kB muxing overhead 1.817058%
Error importing /Volumes/My Book 1TB/Vid/TV Shows/Entourage/Season 5/e_s5_ep1.video.mp4: Invalid IsoMedia File
I haven't run into that particular error before, but the message "non monotone timestamp" suggests where the problem might lie. Is the source video from a live source that you cobbled together? What the error message seems to be saying is that there are two successive timestamps with the same value, instead of incrementing. Perhaps that's where it's getting hung up. You may need to fix that in the source before you can proceed smoothly. Or it may have nothing to do with your problem at all. How's that for a definite maybe?
I captured a 720p source on my HD Free to Air box(external usb hd) as ts stream then put into videoredo and outputed edited 720p ts stream. then into handbrake on pc as 720p xvid with ac3 audio. But Im know going to do x264 with aac 2ch in mp4. But i had already deleted my ts file. So I will be using mpegstreamclip for the rest of the ts streams(i have tried and it works good) but i'm stuck with a couple of 720p xvid files. I will try them in mpegstreamclip also, it should work.
I have no idea what that error message is about. I used qt pro to output that same xvid file to h264 and it worked really good. Thanks for the help tho.
Judging from the fact that I'll get sync errors much less frequently if I decode with QT, there are differences in how time is evaluated. So, if the source clip has some weirdness, it may provoke an error with one particular program, but not necessarily the same in QT. So, functioning in QT is not necessarily a definite sign that the source file is fine; it could be that QT is simply more tolerant.
If there's a way to demux the (possibly) troublesome source and then remux it, that sometimes takes care of a multitude of sins. In your case, with an xvid source, you might want to have avidemux take a whack at it, or something similar. Maybe that will solve your problem.
Good luck!
Combining MKV Audio and Vidoe
By robburne in forum Video ConversionReplies: 4Last Post: 18th Dec 2010, 14:48 -
laserdisc capture: combining audio & video from 2 different players
By leslie80 in forum Capturing and VCRReplies: 3Last Post: 31st Aug 2010, 01:42 -
Combining video and audio files
By lbblock in forum Newbie / General discussionsReplies: 1Last Post: 10th Jan 2010, 11:17 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 19:44 -
Combining Audio and Video in VirtualDubMod
By jwfc in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2007, 22:13
