I have just created a PAL variable bit-rate .MPG file from the contents of my camcorder. The problem is that I want to make a DVD out of it in NTSC format so I can send it to an American friend. The last time I attempted to convert PAL to NTSC was a nightmare, so what can I do?
	"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
	You could try ConvertXToDVD. It handles PAL>NTSC fairly well and may be the easiest way. Or there are other methods: https://www.videohelp.com/convert#4;41
	I would try FAVC - it uses the DGPulldown method for PAL -> NTSC conversion, and also uses HCenc for good quality output. Slower than ConvertXtoDVD, but I think you will be happier with the results. Read my blog here.
	No, just lost and confused now. "It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
	I downloaded FAVC first, and have that squirreled away in my backup directory where I put all the stuff that I download for video tasks. It will not open the file that I have made in PowerDirector Express without being told to look for .mpg files, but that's fine. What really has me around the bend is that when I open the file in FAVC, it keeps telling me to install AviSynth 2.56 or greater, which I have already done. The lack of any proper procedure now has me suffering severe headaches. "It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
  Converting PAL to NTSC?By Djehuty in forum Video ConversionReplies: 17Last Post: 3rd Sep 2011, 14:55
  Converting PAL to NTSC and rip PAL Audio to WAV in VLCBy happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47
  Converting NTSC-PALBy B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 10:06
  PAL DVD to NTSC DVD: CCE is changing resolution (720x480 to 720x576). Argh.By Colmino in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 20:15
  Converting homemade PAL to NTSCBy Kernos in forum MacReplies: 12Last Post: 18th Jan 2008, 16:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
