Long time I have to use TMPGEnc 2.5 for encoding my DV files to MPEG 2. There is option to use Variable encoding in 1 Pass (Constant, Variable and Variable with 2 pass). Other version of TMPGEnc after 2.5, allows only encoding in Variabile mode with 2 Pass. That is too much time for encoding. Why only this option????
Regards.
QUALITY HAS A NAME
The difference between the two is a) speed, and b) predictable file size. Variable 2-pass takes twice as long as single pass VBR. Two pass VBR has very predictable file size and should be about as accurate as CBR encoding. Single-pass VBR will not produce a predictable file size. Why is this missing from one version and not another - perhaps it wasn't working correctly in one release so they temporarily disabled it. I don't actually see the advantage to single pass VBR encoding. If you running time is short enough that file size isn't an issue then use CBR. If target size is an issue then you have to use 2-pass VBR.
Read my blog here.
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 08:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 07:15 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 22:23 -
TmpgEnc 3 - stop it from encoding 544x576 ?
By katykaty in forum Authoring (DVD)Replies: 3Last Post: 10th May 2007, 17:06
