hello,
Excuse me becouse I donīt speak English![]()
it wanted to change hd of my liteon 5025 of 80gb by another one of 320gb, but not it with himself.
I formated the disc of 320gb in my computer in FAT32-64K (FAT32FORMAT) but my liteon does not recognize it.
Erasing/formated the disc in my Liteon it seems that it does not maintain the typical form. I have read something on rewriting the MRB but I have not understood it.
I have followed the instructions that are indicated here
http://www.techolio.com/forums/phpB...opic.php?t=2284
but it does not work.
When I finish and I do a CHKDSK says to me that the disc this in way RAW, and does not recognize the LITEON.
Suggestions?
Mostly likely the new HDD is too large. The firmware of the unit probably can't recognize a drive of that size. It is usually recommended to use the same drive size. Only try a larger drive if you know for sure the unit will support it.
Google is your Friend -
Other people have obtained it.
But I following its instructions not it with himself
The link you referenced above is for model 5045...you have the 5025. It's possible the 5025 won't support larger drives.
liteon hbs112 firmware
By davechubb in forum Blu-ray RippingReplies: 5Last Post: 5th Feb 2012, 13:19 -
Change to Gateway/Liteon firmware
By knights89 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Dec 2009, 16:32 -
LiteON 5005 weirdness
By kenmo in forum DVD & Blu-ray RecordersReplies: 53Last Post: 2nd Jun 2008, 12:05 -
LiteOn HD-A760GX opinions.
By aqtivator in forum DVD & Blu-ray RecordersReplies: 5Last Post: 9th Jun 2007, 18:01 -
LITEON LH20A1P186 Questions
By Nubile in forum DVD & Blu-ray WritersReplies: 2Last Post: 6th May 2007, 03:27
