First, does the structure that DVD Shrink creates play in sync before you convert ?
Second, did you edit the file in Shrink, or just use re-author to strip it down ?
Third, in the avi file, does the audio stay in sync and drift out over time, or is it out by a constant amount ?
Fourth, have you tried AutoGK for the conversion ?Read my blog here.
Have a read of this for instructions on how to fix : https://forum.videohelp.com/topic316884.html#1625975
As to why and will happen again ? Don't know.Read my blog here.
zookeeper wrote"and no i dont like autogk"
And the reason? great proggie IMO! but to each his own..
Try a diff proggie (e.g. FairUse Wizard (there is a very good free one), or Handbrake.
Can never have too many tools!....." Who needs Google, my wife knows everything" -
I don't rip using DVD Shrink but I do sometimes run into audio sync problem too doing DVD to DivX, usually after ripping DVDs that contained extra nasty copy protections.
What seems to solve my DivX audio sync problems is in DVD Shrink (doing movie only):
Re author
Set Start/End Frames
Click the forward button for start frame until I get past the plain, black frames.
Click OK
Save
Encode DivX /XviD from that.
I don't know why it works, I just know that it does for me.
Avi: fine, DVD: audio out of sync
By Sebastian2011 in forum Authoring (DVD)Replies: 2Last Post: 22nd Jan 2012, 14:32 -
Avi to DVD - audio goes progressively more out of Sync
By UnknownVT in forum Video ConversionReplies: 9Last Post: 11th Jan 2012, 14:33 -
AVI to DVD: help with audio sync problems
By tanglemac76 in forum MacReplies: 9Last Post: 23rd Dec 2010, 15:50 -
Audio Sync trouble with Join
By RedDwarph in forum ffmpegX general discussionReplies: 8Last Post: 12th Apr 2009, 09:24 -
Avi to DVD and Audio Sync Issue
By macbuz in forum MacReplies: 21Last Post: 11th Jan 2009, 20:04
