It's important to do your homework before purchasing a big screen television. There's a lot of junk out there that might save pennies up front, but ultimately ends up biting you in the back side with its lack of durability, lesser quality and other problems. However, before considering what brand to buy, you should first determine what kind of big screen TV you're looking for.
LCD (Liquid Crystal Display) TV
Advantages
* LCDs are good for still images and make good computer monitors. So, if you're looking for a screen for TV and computer use, LCDs are a good bet
* Quality LCDs have excellent brightness level pictures.
* LCD flat panels don't take up room and can be mounted on walls. In addition, LCDs are typically slightly lighter than Plasma TVs.
* Quality LCDs have a fairly long life, especially compared to older models (roughly 13-15 years at a six-hour per day pace.
Disadvantages
* LCDs are not good for fast-moving pictures. When an object moves quickly across the screen, the image "delays" (there are trails of pixilation or blockingess), because the screen can't keep up. For this reason, LCDs that are 37" or smaller generally have better image quality because the delay is less noticeable than on larger LCDs.
* LCD TVs have difficulty with black levels
* LCD image looks great when you're staring directly at it, but if you are watching from a slanted view the quality of the image can diminish greatly.
* LCDs are very expensive over 35"
* LCDs sometimes have pixel failure. This isn't a common problem with top name brands, where one or two pixels might eventually die, leaving a black dot here and there. This is hardly noticeable unless you're standing directly in front of the screen (considering a 20" LCD screen has 30,000 pixels). However, in cheaper models where 10% of the pixels could go out, the TV may become unwatchable.
Plasma TV
Advantages
* Top name brand plasmas have a fairly long life, lasting about 20 years at a six hours per day pace.
* A plasma screen has a field vision of about 180 degrees without loss of picture quality. That means you can watch the screen from any angle.
* Plasmas are very bright (about 4-5 times brighter than the average TV)
* They have great contrast ratios (enables them to show better shadow detail)
* Plasmas are generally cheaper than LCDs
* They have excellent picture response. There is virtually no delay (blockiness or pixilation) like with LCDs.
* Doesn't take up much space and can be mounted on a wall.
Disadvantages
* Plasmas can have burn in problems. Plasmas do not make as good computer monitors as LCDs. If you were to leave the Plasma TV on for 24 hours a day and there was an image that remained constant on the screen (like a logo), you would run the risk of that image permanently burning into the screen. However, the chance of this happening is often over-exaggerated.
* Plasmas are not available below 37 inches.
Ebay link removed.
You are asked to contact the webmaster and get permission before you attempt to post solicitations or advertising.
Looks rather similar to this:
http://tv.suite101.com/article.cfm/lcd_vs_plasma_vs_dlp
Except you left out this part:
NOTES: There are a lot of junk Plasmas out there, so stick to top brand names. Panasonic is generally credited for making the best quality Plasma TVs. Also, do not purchase a used Plasma TV on eBay. The first generation Plasma had poor contract and brightness. -
Also the newest premium LCD models (e.g. Samsung and Sony) are significanly closing the gap with plasma on black level, response and width of view but are costly. Also missing in the analysis above are resolution advantages for LCD. Plasmas are usually 720p (1024x768, 1024x1080 or 1366x768). LCD typical display resolution ranges 1366x768 to 1920x1080p.
Plasmas are rapidly dropping in price and can be a good deal. Remember they take a lot of power so factor that in. A 42" plasma can take 400 Watts. The resulting heat adds to air conditioner load so can be effectively 800W-1KW on your power bill. -
CNET's guide is better and more up to date:
http://www.cnet.com/4520-7874_1-5108443-1.html
Non-anamorphic 1.66:1 DVD on LCD TVs ?
By Kweldood in forum DVD & Blu-ray PlayersReplies: 20Last Post: 12th Jan 2012, 06:16 -
New to Plasma/LCD/LED. Should I buy this plasma screen if I'm a gamer?
By Hank Kinsley in forum DVB / IPTVReplies: 4Last Post: 1st Nov 2010, 15:33 -
HDTV Technologies - LED, LCD, Plasma and DLP.
By prankstare in forum DVB / IPTVReplies: 0Last Post: 13th Aug 2009, 00:50 -
Many many Yellowish and Dim LCD TVs...
By SingSing in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2007, 09:41
