Can anyone help. i just got a 2nd hand lvw 5001 dvd recorder. I tried the region free hack (press right key whilst keying in 8000) and now the tray won't open Also did the 296 - 1 region hack.
Any ideas
Cheers
Does it sound like the drive is trying to eject? The front bezel on the liteon dvd recorders can sometime get caught on the left side as you look at the front of the machine. Try pushing the front bezel a little to the right as you press the eject button on the front of the recorder. If this is your problem try just lightly sanding the left edge of the front bezel or rubbing a bit of candle wax on it to help it slide more freely.
Also the Liteon drives in their dvd recorders are well known to have fairly short life-spans, so It may just be that your drive is coming to the end of it's life. It's not too difficult to change the drive, the trick is to find one where FF and Rew works properly. There's quite a lot of info over at http://ccgi.mgillespie.plus.com/liteon/smf/ . Good luck.
BTW, Liteon give their recorders a two year manufacturer's warranty regardless of what the original seller sold it with. If the machine is less than two years old it may be worth giving Liteon a ring and getting them to fix it - they're pretty helpful.
Panasonic S97 tray will not open
By southland66 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Nov 2011, 01:24 -
Harman Kardon DVD-22 won't open the disc tray
By edong in forum DVD & Blu-ray PlayersReplies: 0Last Post: 13th May 2011, 16:11 -
Pioneer DVR-530 disc tray doesn't open
By Alex_x in forum DVD & Blu-ray RecordersReplies: 3Last Post: 22nd Sep 2008, 16:39 -
Problem with Norcent DVD Player, Tray keeps open/closing, tray disc error
By daveshostack in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Feb 2008, 11:41 -
Samsung HD960 Tray stays open
By tommcd64 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 29th Jan 2008, 09:40
