What's the real difference - I thought that a converter must rely n an encoder or am i missing something here?
Usually a 'encoder' is the codec used to convert the file to another format. A 'converter' would usually be a front end or GUI for the codec to make it easier to use. A converter like SUPER uses several different audio and video codecs, along with other programs to feed instructions to the codecs, demux and mux the audio and video back together and perform other operations. A codec just encodes.
The terms are likely all misused at times. -
Originally Posted by redwudz
As for the question, encoders always work with uncompressed material (many of them have options to first decompress imported material). Converters can be built to do it either way and use faster transcoding procedures for some types of material (e.g. MPEG transcoding used in DVDShrink and other programs is fast but it just degrades encoded structures for reducing bitrate instead of decompression + encoding). Frontends to codecs are not necessarily as destructive but in many cases you want to be sure it applies procedures you expect from it (first decompresses, then encodes with parameters suitable for your particular video) and to manually edit or correct something before conversion. If you don't get the desired control over video with a converter (and in most cases you don't) it is better to use a specialized encoder and an editor (like CCE and AviSynth).
Difference DV capture?
By Abas-Avara in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 14:17 -
What is the difference between these Taiyo's?
By ha13may in forum MediaReplies: 3Last Post: 27th Sep 2008, 14:01 -
What's the difference between these two products?
By Waterkips in forum Capturing and VCRReplies: 1Last Post: 21st Apr 2008, 00:40 -
what is difference to + and - DVD-R and RW?
By snadge in forum DVD RippingReplies: 2Last Post: 27th Feb 2008, 12:14 -
Can YOU Tell the Difference ?
By Seeker47 in forum DVB / IPTVReplies: 14Last Post: 19th Nov 2007, 12:59
