With Adobe Premiere Pro 2.0 I get the error:
Can't Activate Recorder. Try Resetting Camera.
With Nero Vision I get a similar error:
Failed to initialize capture device. Please check the device settings.
Windows Movie Maker crashes if I switch to capture mode. Clearly there is something wrong here, but what? Where do I look? It used to work fine.
Thanks,
-Mike
Results 1 to 13 of 13
If possible, test your camera and firewire cable on another PC. If it doesn't work, change the cable. If that works, put the new cable in your machine and test. if it doesn't work in either PC with different cables then the camera's port may be the issue.
Read my blog here.
Done. Cable and camera work fine on the other computer. Used to work fine on this computer too. I suspect errant codecs more than anything else, but haven't found a program that actually works for removing bad codecs. Another thing to try would be a capture program that does some troubleshooting to figure out why it's not working, but I don't know of one. I also tried WinDV and got the message:
Can't create CaptureGraphBuilder
I am amazed that no software has been written that examines the system to figure out why it's not working. Nor software that automatically goes through the DirectShow filters and figures out what should and shouldn't be there. -
Getting back to this after a while...
I tried Filmerit and indeed think it has located the problem - but how to fix it? Under Sony DV Camcorder it says:
#Error F02 - No CLSID
#Error F10 - No Filterdata
Repair is grayed out.
Any ideas?
Thanks,
-Mike -
Oops! Just read the instructions. :)
Ok, I deleted all things causing erros. The Sony errors come back as soon as I turn the camera back on. No change. Any other ideas? -
possible directshow problem. try this.
http://www.riverpast.com/en/prod/dsdetective/download/
and make sure your DVavi codec is set to microsoft's. it's in the registry as something like hkey local machine/software/microsoft/windowsnt/current version/drivers32 - vidc.dvsd = msvidc32.dll if it's set to the ms codec.--
HEY GUYS...
GOOD NEWS!!!!!!!
If you get the capture error "Can't Activate Recorder. Try Resetting Camera" and you have recently installed a codec pack...simply uninstall it and restart Adobe and try again...
WOW it worked
I'm new to this and I want to thank you all for this forum...
Love you all
A happy man,
ERIC -
hey guys
am having the same problem - no codec packs installed
can someone help pls
thanks
kev -
you could try installing the free enosoft dv package, it will replace the microsoft dv codec, which may be missing/damaged?
Resetting ffdshow
By PERSHON in forum Newbie / General discussionsReplies: 17Last Post: 11th Mar 2011, 13:23 -
HD DVD recorder and Standard Definition camera?
By Jmin in forum DVD & Blu-ray RecordersReplies: 5Last Post: 12th Nov 2010, 11:25 -
How can I de-activate
By Marty R in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 2nd Nov 2009, 06:27 -
Confusion with SONY Video Camera Recorder
By orfajackson in forum Newbie / General discussionsReplies: 1Last Post: 12th Apr 2009, 13:52 -
Resetting PC?!
By Squid_uk in forum ComputerReplies: 30Last Post: 15th Apr 2008, 17:45
