ive got a game capture of my daughter driving 1st attempt in toca 3, and need it small enough to upload
original file size is 3 gigs, ive converted it to svcd so she can show her mum but i need it small to upload
i got xvid and divx codecs installed, ive got tmpeg encvoder, vdub and its confusing me in vdub
i click on the configure when selecting xvid compression type in the length (3 mins 47 sec) and try changing file size to 5 or 10 meg and it always comes up about 25 meg
is there a 1 click or whatever solution where if i put in i want it 5 megs itll sort it to be that size?
Use a lower bitrate.Originally Posted by matneaves
file size = running time * bitrate
Did you compress the audio too? -
Did you check the script to see what it was doing ?
Did it open a virtualdub window ?Read my blog here.
A : Input total time length of video
B : Input audio type and bitrate
C : Back at top , enter max file size in kb ... 20mb = 20000kb
In the middle will be reported average video bitrate required to acquire max file size as entered .
If audio is already compressed , consider "direct stream copy"
MP4 is to big. How can I lower the size?
By DonGallego28 in forum Video ConversionReplies: 6Last Post: 16th May 2013, 04:11 -
Converted file has lower volume
By pooksahib in forum Video ConversionReplies: 2Last Post: 26th Dec 2010, 04:22 -
Lower output file size from Vegas
By Squid_uk in forum Newbie / General discussionsReplies: 1Last Post: 5th Feb 2010, 15:28 -
Size of Capture file
By gasport in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2009, 16:46 -
Smaller file size after Video Capture (help)
By convoy71 in forum Capturing and VCRReplies: 4Last Post: 4th Apr 2009, 18:05
