can i burn a video by using nero and add subtitle to that video simultaneously? if no, suggest one that can do. if probably freeware
I'm assuming you mean to create a DVD with subtitles? Subtitles are added during 'authoring', when the DVD format is created. See 'WHAT IS' DVD to the upper left on this page for the DVD format and specifications. I don't know if Nero can do that, maybe NeroVision, but if you have a DVD compliant MPEG-2 file, you can use a freeware authoring program like GUI for dvdauthor and it can handle most subtitles.
Or use a freeware AVI to DVD converter that handles subs: https://www.videohelp.com/tools/sections/all-in-one-dvd-converters
Other ways to add subs: https://forum.videohelp.com/topic267417.html
For more subtitle info, look to our Subtitle forum.
EDIT: Or if you are asking about AVIs and subs, just put them in the same folder and burn it as a data disc. Nero or ImgBurn can do that.
burn in a subtitle in Xvid without re-encode
By Cazz in forum SubtitleReplies: 6Last Post: 3rd Sep 2011, 00:28 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
burn subtitle and font size
By sneike in forum ffmpegX general discussionReplies: 10Last Post: 6th Oct 2008, 17:02 -
Burn IDX Subtitle ONLY to CD With AVI
By stoneferry in forum SubtitleReplies: 4Last Post: 22nd May 2008, 03:13 -
Burn subtitle into AVI. How?
By antoniong in forum ffmpegX general discussionReplies: 15Last Post: 17th Feb 2008, 08:04
