can any body suggest this little lad he best freeware that can rip a movie from dvd and automatically convert it to avi format?
Try AutoGK. But nothing is completely 'automatic'. And AGK doesn't decrypt, so you will need a program like DVD Fab HD Decrypter first for most DVDs and especially the newer ones. Other programs that can do similar here: https://www.videohelp.com/tools/sections/dvd-to-avi-divx-xvid
There is also a freeware version of FairUse Wizard that you may find easier to use than AGK. But with most any of these programs you will need to decrypt the DVD first, especially the newer ones.
Your Recommendation for Best Freeware DVD Ripper and Converter
By charmedlife417 in forum Video ConversionReplies: 22Last Post: 28th Oct 2011, 13:36 -
Freeware dvd ripper editor?
By pursuant in forum Newbie / General discussionsReplies: 2Last Post: 18th Feb 2010, 19:27 -
Best Freeware for Avi to DVD
By videonewbie69 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jul 2007, 08:08 -
Can someone recommend a freeware program similar to AOA dvd ripper?(youtube
By tecmobo34 in forum Newbie / General discussionsReplies: 2Last Post: 28th May 2007, 17:16 -
Convert a dvd to avi tools which are freeware
By loninappleton in forum Newbie / General discussionsReplies: 2Last Post: 7th May 2007, 14:13
