Hi all.
I'm using v2.5.3000 to convert some video.... and it has worked fine till now.
I've only ever converted avi's/mpg's but this is a mkv file.
File stats are...
Duration: 01:45:21.1
Video: h264 1270x720 NTSC
Audio: ac3 48KHz 0Kbps
When added it takes the size to 6.83gb.
I then use autofit to bring down to 4.37gb.
But once converted, it is still 4.63gb.
I've attached the log incase it helps shed any light as to what is wrong.
Thanks in advance
hsm.log
Results 1 to 13 of 13
Try the newest version, I believe it was released to address this problem.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Hi ChrissyBoy et al,
I'm having the same problem with my mkv files. They just don't scrunch down quite enough. At least I think it's caused by the mkv's because the avi's seem to be fine since you tweaked the programme a couple weeks back.
My log follows
svcd2dvdlog-20070828225631.txt -
Its not picking up the bitrate from the audio and so doesn't take this into account. I will investigate.
I've experienced the same on a couple of occasions when trying to put 6 or 7 .avi files onto a disc (Sopranos episodes). Autofit them and everything seems fine until it comes time to actually burn the converted files onto a dvd. A couple of times they've come up just fractionally too big.
As a work-around I've added an additional asset (a small .avi clip- 40mb), auto fitted everything, then removed the small 'filler' file to reduce the size even further. This has worked for me so far. -
Have a look at https://forum.videohelp.com/topic285423.html#1413094 it may mean that you don't need the filler file...Originally Posted by daz72SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
ChrissyBoy,
Is your suggestion to daz72 what the rest of us in this thread should be trying? ...or have you got something else up your sleeve?
Dan -
No - the mkv issue is different and i will be taking a look into it ASAP.
The bug with mkv files leading to an oversized image still seem to be present in the latest version (2.5.3300)
Regards,
hopester.
Avi file too large to burn to dvd
By MLPoison911 in forum Newbie / General discussionsReplies: 20Last Post: 12th Feb 2014, 13:07 -
Should converted .mp4 file be this large?
By brassplyer in forum Video ConversionReplies: 9Last Post: 3rd May 2011, 14:17 -
Is there a way to put a 'whole' DVD into a converted file?
By reapur in forum DVD RippingReplies: 5Last Post: 6th Feb 2011, 20:33 -
large mp4 file to dvd
By GP_Wouter in forum Video ConversionReplies: 6Last Post: 3rd Nov 2010, 14:22 -
Burning large file onto CD or DVD
By Tom in HD in forum MacReplies: 3Last Post: 2nd Jan 2009, 15:06
