What is a good program that will allow me to encode MKV's to DVD's where it will encode the video and both audio files at the same time and have high quality? I tried using convertxtodvd but the outlines of some of the characters are a bit jagged and when I extracted the audio and video from the MKV's and used TMPGenc xpress the video was fine but the audio and the video were different lengths.
Results 1 to 13 of 13
Give SVCD2DVD a try.
You may need to install the .NET Framework 2.0
http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15...displaylang=en -
Thanks but when I use svcd2dvd I get the same quality I had in convertxtodvd.
You will - they are both based around ffmpeg. This makes them fast, but ultimately very similar in quality of output. FAVC uses HCEnc. It is slower, but the quality will be higher.
Caveat : quality is dependent on source to a larger degree. If the source quality is low to medium then the output will also be low to medium in quality - garbage in = garbage out.Read my blog here.
Just in case you missed it, click the link....
https://forum.videohelp.com/threads/130534-Metadata-in-AVI-files?p=2077765&viewfull=1#post2077765
And you thought that reason for digging up this old thread by posting to it was a good one ?
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
DVD to mkv without any re-encoding?
By cal_tony in forum Video ConversionReplies: 8Last Post: 18th May 2010, 15:43 -
problem encoding 3 mkv's to DVD
By pas7680 in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 2nd May 2009, 05:19 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Encoding HD DVD into MKV Files
By donpato in forum Newbie / General discussionsReplies: 2Last Post: 22nd May 2008, 16:37
