my pc crashed and l had to reboot it manually, but now there is this black screen with sentences such as fixed disc 0, fixed disc 1, asking me to press the F1 to resume each time l start my pc, what does it mean? and how to start my pc without this screen showing up? thanks
Results 1 to 9 of 9
Shut it down , remove power .
Remove main cable connecting hd's , and firmly reconnect it the same way it came out
Repeat with power connectors .
Repower system
Enter bios , check clock ... if not correct date , could be time for battery change .
Failing this , it's replace the main cable attached to drives .
Next comes replacement psu , if needed .
What happens to bad psu's voltage :
If 5volt supply to drives fails , system will not see drives , yet hds power up , cd/dvdrom can be opened / close by button
If 12volt supply fails , system can see drives , but unable to access . -
Apparently it can't boot. Sometimes when Windows crashes, it scrambles the hard disk so badly that it is unbootable. Or there may be a hardware failure in the hard disk (or power supply, or connectors) that caused the crash and prevents you from booting).Originally Posted by ieh4f
Anyway, if you can't understand this you have no hope of fixing it yourself. You need to get it to a shop or a knowledgeable friend to repair. -
If AlanHK is right, then boot to CD, and use your Windows install CD to repair the OS.
it is not like l cant start or restart my pc, it is just very annoying that l have to press F1 to start my pc every time, how can l get rid of that screen(which also show processor info, hard disc detected, cd-rom detected etc)
sounds like the motherboard bios screen has somehow become stuck, and not booting correctly. look at the settings in the bios for a quick boot or fast boot that can be set. but it may be with the age of that motherboard/cpu it's just dying. lots had capacitors that start leaking with age.
In that case it's forgetting your settings each time.Originally Posted by ieh4f
If you reboot without powering off, does it still hang in the BIOS? If it only hangs on a cold start, you probably need a new BIOS battery (a cheap button battery). The date and time would also be wrong.
Otherwise, look at all the settings on the BIOs. There may be an option to save the new settings (disk parameters, etc). Or you may have set it to ask each time which device to boot from. Just step through all the screens and settings of the BIOS, especially boot devices or similar wording. You have to explicitly save settings (often F10) before exiting and continuing to boot. -
Replace the CMOS battery as others have suggested.Originally Posted by ieh4f
see link below:
http://www.computerhope.com/issues/ch000239.htm
Computer keeps rebooting again
By Illusionist in forum ComputerReplies: 5Last Post: 11th Apr 2011, 18:19 -
xp keeps rebooting
By Illusionist in forum ComputerReplies: 1Last Post: 8th Apr 2011, 12:43 -
TMT3 is Rebooting My Computer
By wulf109 in forum ComputerReplies: 6Last Post: 21st Oct 2010, 12:09 -
randomly rebooting computer
By minidv2dvd in forum ComputerReplies: 0Last Post: 8th Sep 2008, 23:08 -
Box keeps rebooting after...
By makntraks in forum ComputerReplies: 8Last Post: 24th Jul 2007, 22:10
