First off i'd like to say hello to everyone seeing as this is my first post on these forums. Anyways, i'm looking to play MKV with highest quality video. Which programs and codecs would be suitable for this?
	MKV (Matroska) is a container, just like .avi and .mp4. What filters you need will depend on what is inside the MKV file. You can try a tool like MediaInfo to identify what is in the container. You could also use something like mkvextractgui to see what is inside.
 You will also need to install the following: Haali Media SplitterSome people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
	I've gotten Haali Media Splitter, ffdshow, CoreAVC, and Media Player Classic. Now how do I set Media Player Classic to use the CoreAVC codec?
	1: Install FFDShow
 2: install CoreAVC (I recommend not installing the Haali Media Splitter that is included with this installer, but instead installing Haali seperately.)*
 3: Install the Haali Media Splitter
 4: In the ffdshow settings, disable H264/AVC decoding.
 5: Reboot (highly recommended)
 6: Configure MPC (the following pictures show how I have mine configured).
 7: Close/Restart MPC (not sure if this is necessary, but it can't hurt).
 *I recommend installing Haali media splitter separate because Haali often releases new versions/bug fixes. Installing it separate makes uninstalling and installing a new version easier.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
  MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-rayBy Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19
  How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45
  Quality difference with MKV?By pixaren in forum Software PlayingReplies: 4Last Post: 21st Jun 2011, 12:12
  Best quality option to convert 1080p mkv to 720p mkvBy carlmart in forum Video ConversionReplies: 5Last Post: 14th Mar 2010, 08:17
  mkv to xvid qualityBy dogano in forum Video ConversionReplies: 8Last Post: 26th Jan 2008, 09:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
