Is anyone else having trouble using VFAPI after the lastest Tmpgenc?
I can't seem to get VFAPI to take any .tpr files from Tmpgenc 2.51.
I had the same problem
download the latest VFAPI plugin from TMPGEnc
http://www.tmpgenc.net/files/TMPGEnc-2.51.33.127-vfp.zip
and install it - then everything works again
seems they made some update to the VFAPI supportyour pal,
Stinky -
http://www.geocities.com/santajon/vfapi-error.jpg[/url]
here is a pic of the error -
Nerk01,
I had the same problem. Do this:
You probably have the old version of TMPG, right? Go to the directory and unregister VFAPI by doubleclicking on the uninstall-xxxx.bat file. (don't know the exact name).
Then go to your new 2.51 directory and double click on install.bat to register the new one.
It worked for me.
hope that helps.
sk
VFAPI Codec Problems
By [K]eep[A]way in forum Newbie / General discussionsReplies: 20Last Post: 8th Sep 2011, 06:40 -
What is the lastest on MediaPortal?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 0Last Post: 1st Feb 2011, 06:10 -
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 14:46 -
Direct download mirror link to lastest version ffdshow
By roma_turok in forum FeedbackReplies: 1Last Post: 17th Dec 2008, 04:08 -
Lastest Version of DVDFAB Express
By Ensign in forum DVD RippingReplies: 5Last Post: 14th May 2008, 10:18
