  1. While getting a quotation for our Cine reel to DVD conversion, I noticed that the equipment they use is a Rank Cintel Mark III Digiscan. One idea I had is that since we've got 13 reels of this stuff, it might be cheaper to buy a scanner, do the work, then sell it second hand. I think perhaps that it might have been out of our price range - anyone got any idea how much one of these babies costs?
    cheers.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    cheers.
    Are you serious? These are ultra expensive and require a highly skilled operator. Then the companion color correction system and recorders are well into the six figures and a good colorist requires $80k/yr as does the system engineer to connect things properly.
    This is an out of warranty used one
    http://www.broadcaststore.com/store/prod_detail.cfm?eq_id=426100
    A this decade model will set you back a cool $780K not counting the color correction system and recorders.
  3. Member Marvingj's Avatar
    Apr 2004
    Death Valley, Bomb-Bay
    Ha Ha We used to have one at the Television network I work at, its very expensive & you better have some kind of maintenance contract because its going to make you cry if its breaks down.
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
  4. Well that's kind of what I figured.
    Never having attempted to find out the particulars of this kind of transfer before, I didn't have any idea about the costs of the kit they use. Obviously that idea's out of the window.
    Thanks.
    Jan 2007
    Republic of Texas
    What type of film is on those 13 reels? 16mm? 35mm? Super8? If it is 16mm, you can get a telecine projector on ebay, usually for less than $500. You'll also need a film-to-video transfer box, consisting of a front-silvered mirror and rear-projection screen. Use a good 3-chip video camera to capture the images projected onto the transfer screen, and you can get very satisfactory results. I have used both a Rank Cintel and a telecine projector. Yes, the expensive scanner is better, but for the price, it is not that much better than telecine, as long as you are capturing the projected images with a very good video camera.
    Most of the scanners, used, start at around a quarter of a million bucks. I don't think you'll want that for just 13 motion picture reels.
