Well guys, I need your help again. I'm trying to get an animation to look good on dvd. Below is an image file. The animation is made in AnimeStudio at 24fps. I encoded it in TMPGEnc Plus with 3:2 pulldown playback and it just seems jaged when viewed on a non-progressive tv. On my lcd tv with progressive dvd player it looks fine. It's most noticable on the tree tops. Any thoughts would be great. I have tried quiet a few different settings with different software but I must be missing something.
http://www.posemotion.com/video/toondvd.img
Your pulldown doesn't appear to be correct. The pulldown should be from 24 fps to 29.97 fps. Yours is 24 fps -> 30 fps. On a progressive TV this won't be an issue because it eschews the pulldown and presents 24 fps. On an interlaced TV the 30 fps output might be causing your issues. If tmpgenc is applying the pulldown, encode without pulldown, then use DGPulldown to apply the correct pulldown and test again. I suspect that tmpgenc is applying 3:2 pulldown correctly, but not taking into account the base framerate of 24 fps, instead of 23.976 fps. DGPulldown can apply specific pulldown for this situation.
Read my blog here.
Can't you output video at 29.97 fps directly and avoid any rate conversion?
Or maybe use 25 fps (PAL) if your set can use that.
40 second animation
By Ken-B in forum Off topicReplies: 3Last Post: 24th Nov 2011, 09:23 -
DVD Lab Pro help! Play animation after pressing button for playing video.
By visualhippocracy in forum Authoring (DVD)Replies: 3Last Post: 26th Mar 2011, 09:21 -
Resizing Animation
By roflwaffle in forum Newbie / General discussionsReplies: 4Last Post: 19th Jul 2010, 12:04 -
StormCel Animation
By Noahtuck in forum Latest Video NewsReplies: 0Last Post: 26th Jun 2008, 22:09 -
I've got an animation I did in MPEG format and I want to burn it to a DVD
By el_cid in forum Newbie / General discussionsReplies: 6Last Post: 3rd May 2008, 15:11
