Hey all,
I know I should probably start with something simpler, but I've got an AVI file which includes subtitles (okay, GSpot says it's a DivX inside) and I'd like to turn this into a DVD.
Are there any tools (hopefully free) that I can use on the AVI to re-extract the subtitles? Or is it possible to simply create the DVD from the AVI with the subtitles, burned in or not? What are my options?
Thanks in advance!
ConvertXToDVD would be my first choice. It handles subtitles and does well with PAL<>NTSC conversions also. It's not free, but it's worth the cost, IMO. With a DVD, you can have selectable subtitles.
For freeware, FAVC or DVD Flick are popular, but I'm not familiar with their subtitle handling.
I would also highly recommend the freeware ImgBurn for burning DVDs.
And welcome to our forums.
EDIT: After re-reading your post, are you asking about hard subs? In other words subs that are burned into the video? Those you usually just pass through the encoding to MPEG and leave as is. They are all but impossible to remove anyway. Most subbed Xvids or Divx files have the sub as a separate file, often .srt format. It would be in the same folder as the video and generally have the same name. Those can be used in a DVD to create selectable subs. -
What I mean is, I don't really care if the resulting DVD has hard subs or selectable ones.
Creating MP4 or DVD from an .avi and a .srt file using Nero 10
By criggs in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2011, 02:04 -
Noob question about converting ripped files to AVI
By gingerman74 in forum Video ConversionReplies: 4Last Post: 20th Mar 2010, 23:39 -
Noob with auto gk dvd to avi question
By kaylec in forum Newbie / General discussionsReplies: 4Last Post: 6th Oct 2009, 17:53 -
Noob Question: What subtitle files do I choose/use for DVD player
By peggypwr1 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Mar 2009, 16:24 -
Real noob question about DVD Movie files
By Thom Yorke in forum Newbie / General discussionsReplies: 3Last Post: 25th Feb 2009, 11:50
