  1. Member pchan's Avatar
    Mar 2003
    Singapore
    Hi All,
    It there anyway fix the broken file structure ? I use PGCEdit but don't know not exactly how to fix it.
    Appreciated your helps. Thanks in advance.
  2. Member Seeker47's Avatar
    Jul 2005
    Originally Posted by pchan
    Hi All,
    I've had some good results with FixVTS (which I think those evil MV bastids killed off not too long ago), but that was on things where the file structure problems were probably not too severe. I don't know how bad it has to get before that tool would become ineffective.
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    What, specifically, is wrong with it ?
    Read my blog here.
  4. Member pchan's Avatar
    Mar 2003
    Singapore
    Tried FixVTS. But no lick.
    Home brew video. It's such a pain to take the VOB files and rebuild the whole thing.
    Nov 2003
    If nothing works, take VOBs and drop it into IFOEdit program. It will create new IFOs and BUPs for your video.
    Dec 2006
    Here,where do you think?
    First try to open in shrink to create a new backup(VIDEO_TS folder), try it...
    On home brew video I'd use Vob2mpg> then on new MPG use proggie like DVDFlick....or ConvertX2DVD....and burn..
    But if it fails try VobEdit>IfoEdit for new DVD structure...good luck!
    " Who needs Google, my wife knows everything"
    Apr 2004
    Miskatonic U
    If you have to re-build, do not use ConvertXtoDVD, as it will re-encode. Use VOB2MPG as suggested, but then use an authoring tool like GUIForDVDAuthor.
    Read my blog here.
