    Nov 2006
    today while burning some movies my nero(burning rom 7.8.5.0) produced 6 shiny coasters, not in a row, but still.
    what's that about???
    ps - i'm in the process of learning imgburn.
  2. I'd say keep on learning Imgburn - I've always found Nero to be unreliable- makes too many coasters - so I don't use it.
    It's simple really!
    Feb 2007
    China
    been using ROM for a couple of years now. always version 7, always updated. never had a problem that was a direct cause of ROM's malfunction.
  4. Banned
    Freedonia
    offensekilla - The following guide might of use to you:
    http://www.digital-digest.com/~blutach/pgcedit_guide/burning_with_pgcedit/burning_with...pgcedit_v2.htm
    It describes how to use PgcEdit to generate ISO images that ImgBurn can burn. This is how I make DVDs all the time. This process works reliably.
    I hate Roxio - passionately. I have mixed feelings about Nero. Nero is great for making data discs and audio CDs, but I wouldn't use it for anything else. Nero is really not your best option for authoring any video format disc - VCD, SVCD and DVD. If you want to make VCDs and SVCDs, use VCDEasy and then burn the BIN/CUE file with something (Nero is fine for burning BIN/CUE files). However, I stopped using Nero years ago for burning any DVD and I use ImgBurn exclusively.
