I have a movie on my computer but it wouldnt play. It Video_TS and in there there are IFO, BUP, and VOB files like how its suppose to be. but i tried opening the first file and it doesnt automatically play the whole dvd, I have to play each VOB file separately. Is there a way to fix this? I'm thinking of making the files into an iso and maybe load it like that so it would play. does anyone know how to do this? thanks
A ISO conversion won't help.
What player are you using? Unless it has a DVD option, it may just play each VOB by itself when you select them.
There are plenty of software players that are DVD compatible. VLC, The KMPlayer, probably MPC and several others. You usually select 'DVD file' in the open menu. -
Have you tried opening VIDEO_TS.IFO? That's usually the one that runs the whole enchilada.
DVD Shrink should be able to create a iso version of the DVD structure you describe. Once you've got the ISO, you can try Daemon Tools to mount the ISO on a virtual DVD drive and it should play on your PC with your DVD player software.
Streaming ISO Movies - What Do I Need
By mn072065 in forum Media Center PC / MediaCentersReplies: 14Last Post: 11th Dec 2011, 19:55 -
Help making ISO with ImgBurn
By stantheman1976 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jan 2009, 18:04 -
free software for making cd-rom iso's
By Dr.Gee in forum ComputerReplies: 1Last Post: 27th May 2008, 19:00 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03 -
Making an Iso from an I00 file
By t_jay17 in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 16:50
